rear shocks
took the clio out for a spin today,came up to three humps doing around 100,went over em and the back end hopped off the ground,came down at an angle and got into a nasty speed wobble,im convinced it wouldnt have bounced so badly if there was stiffer shocks in the back,its a valver i bought last fri,lowered 35mm with std shocks on 185/50/15s,any suggestions for rear shocks?
  A SHED!
If you can afford it..... spax adjustables. Ive got some for my 16v. Brilliant handling, although if the shocks were harder when you went over those humps Im sure it wouldve been even more painfull.
i dont think it would have started bouncing with a stiffer rear end,cos once that happens u essentialy have to control for a few seconds.ill check out prices on the spax,thanks
  FRST and 106 GTi
LOLLL
go LEDA! btw, their pricing is on EACH... not both!
How do you adjust koni sports on the back? rt/valver/willy.
