rear wash/wipe issue
Hi all, ive got a 95 RT, Phase 2.
when i go to use the rear wash, i get a pumping noise, as though water is going through, but nothing happens
also, when i go to use the rear wipe, i get the cliking noise in the passenger footwell fusebox thing, so thre is power (plus i metered accross the wiper and there is intermittant voltage as should be expected) but i get FA movement from the rear wiper.
does it sound like the motor has gone?
any suggestions on the washer issue?
cheers
Yes, the motor can go, but i just belt mine and it works fine again.
the rear wiper pump pickup sits higer than the fronts to make sure that the fronts have priority jsut incase you run low on fluid.
checked the fluid level?
the fluid level is alright (accidentally pulled the little connector out, and water pished out :oops: ) so im hoping that issue is just a blockage in the jet (where else could it be blocked? i dont know how the water gets to the back)
as for the wiper itself, im thinking it IS the motor, will give it a look at tomorow
thanks guys
you need to check for a earth(all the time) and a feed at the moter(when you operate the stalk).
