Red line/Rev Limiter.........
  133/225/CLS AMG
I know people have said before but what revs does the rev limiter kick in at. Isnt it set lower until the car warms up as well?
Anyone know that the top speed of a 172/182 in each gear is before hitting the limiter????? I aint hit the limiter yet and if I ever do I m sure I wont be watching the speedo that closely lol!
When warm, i get the shift lift on at about 6,900rpm ish, and then the limiter kicks in about 7,200rpm.
Cant say ive really looked what speed in doing at the limit in each gear. I dont really drive that fastBut at a rough guess.
1st...no sure
2nd 62-65mph
3rd 85-90mph
4th not sure
5th not sure
1st... 40
2nd... 62
3rd.... 90
4th.... not sure
5th.... definatley not sure :)
Thats taking it to just before the limiter, ie when the ikkle green gear change light comes on. All indicated speeds.
  VaVa
Gear ratios were altered slighty for the 182, but the 172 Mk2 is
38 in first
62 in second
90 ish in third
112 in fourth
143 in fifth (theoretical)
iirc
Ratios for 182 are;
1st 5.4 mph / Thousand rpm = 39.25
2nd 8.9 mph / Thousand rpm = 64.25
3rd 12.5 mph / Thousand rpm = 90.65
4th 16.1 mph / Thousand rpm = 116.25
5th 20.9 mph / Thousand rpm = 151.25
Thats taking the rev limit as 7250 rpm. If thats what it is.
[Edited by lagerlout1 on 08 April 2005 at 9:35am]
  Nippy white cup
Or with Rsport ;)
38 in 1st 7500
68 in 2nd 7500
95 in third 7800
125 in fourth 8k
143 ish in fifth dont know
[Edited by Chris nnic on 08 April 2005 at 9:37am]
  VaVa
Quote: Originally posted by Chris nnic on 08 April 2005
125 in fourth 8k
:eek: Now that would be nice!! I love fourth gear.
I hate changing into fifth when giving it some. Everything starts slowing down, it would be great to hold on to fourth for a few more rpm...
  172 ph1
I asked Renault what the 172 rev limiter was and the reply was that with coolant temperature below 75 degrees c it was 6700 rpm all gears.
With coolant temp above 75 degrees c it is 7250 rpm on first, second and third, reducing to 7000 rpm on fourth and fifth (off beachy head I assume).
Only problem then is the temperature guage has no numbers on it, so god knows where 75 degrees is.
As for top speeds in each gear it depends whether you have mk1 or mk2 172.
  megane coupe F7R
On my valver
1st= 40mph
2nd= 62mph
3rd=90mph
4th=110mph
5th= 130mph@6500rpm
[Edited by Andyvalver on 08 April 2005 at 5:09pm]
  Clio Mk1 Hybrid
my valver
1st 40mph
2nd 65mph
3rd 90mph
4th 126mph?!?!
5th god knows lol
mine seems to now have some sort of hybrid box as it goes to 126 before the limiter in 4th, all these speed tests were conducted on my very own test track btw ;)
Dave
5th in a special and sadly missed 172 was over 148 and still pulling well - but whod wanna try that out eh? (Gps verified before anyone asks)
My 182:
1st 38mph
2nd 62mph
3rd 90mph
4th 115mph
5th 142mph
They were all pretty much to the limiter apart from 5th not sure what rpm that was.
  Clio Mk1 Hybrid
yeh it still pulls in 5th around a ton at 4.5k not maxed it out yet but pulls as well as it did with the last box in and has defo got a longer ratio
Dave
