remote desktop question
Car  Elise/VX220/R26
Just setting this up at the moment. The host computer at the moment I dont have an administrator password set up on it. Do you have to set up a password in order to connect using the remote computer? On the laptop I'm using to connect to it its asking for a username/password
ta!
use a username and password thats set up on that specific pc
try
Administrator
password: leave blank
if not just any persons account on that pc should do it
add the local user to the administrator group then it should work. (not the correct way of doing it, but on a normal household this is the easiest way)
yeah I think you have to have a username and password whichever way you do it. Wont allow you to leave password field blank. I've just added a password to the administrator account on the host pc and it works.
Remote desktop won't let you login if you have no password (by default anyway).. so you have to set at least something.
i just presumed ms , where slack enough to let somet like that happen , i knew it works on most ppls pc`s when at em ,
found out you can set the host pc to auto login to get round the problem. I have a tower with no monitor I want to run purely off remote desktop so I'll have to do that one with auto login
You don't need to login locally.
And, if it's XP, as soon as you remote desktop it'll log the local user off as it has a 1 session limit.
