Removing badges.....
Car  Clio 200
I am looking at removing the Reanult & Sport badge on my 182 and just leaving the Clio badge on the other side. Is it difficult to remove these?
The Renault and Sport badges are glued on. I just got a credit card, and wedged it behind the badge and pried it off.
Then just tidy up the glue remains on the car. Easy :)
Dont you just pull them straight off like the phase 2s?
If they do, they will have 3 'prongs'. Be careful not to break them when you pull them off! I broke 1, it clips on fine with the 2 left :)
2 'prongs' that push into holes in the boot. Hence why if you remove this badge, you're left with two ugly holes. Careful not to break these too, as I did!
If you want to remove that badge, use the same technique, and just gently 'pry' it upwards.
