Removing ECU bracket
Da
  Less
On a 182, I've got all the bolts and fixings out etc but I now need to separate the top 'cover' from the remainder of the bracket so I can remove it from the bay. It looks like it should just slide/pull off but doesn't! Anyone any ideas please?
Cheers!
  BMW M135i
On my 1.6 it did just pull off, a good yank and it came off. Don't know if the 1*2 one is any different?
Da
  Less
Right, done it and it's all back together! Phew! Hardest bit was getting that top cover off but in the end with a bit of persuasion it did just pull off!
Cheers for the help guys :)
5 Year Bump...
Removed all the bolts holding the bracket to the car. There are two almost impossible to get at bolts inside the bracket they look like there holding the ecu inside the bracket, do these need to be removed aswell?
