removing lambda sensor
  ValverInBits
If your really committed, get a grinder and chop it right down so that you can get a 22mm socket around it. Then you can really start showing it some leverage. Tough bolts will sometimes loosen a bit if you literally smack the bolt head with a hammer. The shock can free the threads a bit sometimes. As above, heat may also do it good.
