2 x bolts in wheel arch ( only remove the front bolt from each arch, if you remove both you will also detached the rear bumper mount which you dont need / want to do)
2 x torx bit screws on top of bumper when boot open
2 x bolts under bumper in the middle of the car (found around the same sort of distance apart as each end of the number plate)
also dont forget the rear number plate light when first taking it off
