removing spark plugs
ok , despite trying numerous times, i think im gona have to let the garage adjust my handbrake (99 clio mark 2)
however, id like to some other bits, notably what sized tool do i need to remove and check the spark plugs? 1.2 engine
thanks
0.9mm gap for spark plugs but if there out just get new ones.
Any small thin spark plug tool will work to get them out plus you'll need a long extendion bar but most tool kits have them.
To remove the plugs disconnect the HT leads using the tool which is on the manifold make sure that no dirt can get in the cylinder so clean the area a bit then remove the plug carefull and put a new or check the old one and put it back in.
