Removing the Dashboard
  Clio 1.2 16V
How hard is it to remove and refix the dashboard in a 05 Clio? Need to fit new tweeters and the instructions say to remove the dashboard, is there no way around this? Any help appreciated! :)
Jekyll
Pull door rubbers down
pull a pillar plastics off
unscrew t30 torx on either side of the side of dash
pull dash strips off
unscrew 4x dash screws (t15)
unscrew 3x vent screws (t15)
take top steering shroud off
sit in center of car and pull.
danward
  TTS
Its a fairly easy job, I had my dash off, tweeters changed, and dash back on again in a couple hours after work one day.
  182
i got the drivers side out just by wiggling it out through the hole, but the hole on the passenger side wasn't aligned properly tho so had to unscrew and lift the dash a bit.
