Removing Wings?
  fiesta 1.25
Does anybody klnow how to take off the wings do i need to remove front bumper first?anyone got a guide?? (fubar??)
  Civic Type-R
Ye you will have to take the front bumper off as there are 2 bolts holding the wing on behind it. Also prob the side skirts and the arch liners will need to be unbolted from it.
  Ultra 197 ex 172 Cup
you can do it without removing the bumper, just loosen the bumper bolt behind the wheel arch lining which you have to remove first. -
take wheel off
remove all the wheel arch lining.
open bonnet and unscrew bolts
loosen the bolt that holds the bumper on, then undo the bolt that holds wing on.
undo bolts that are hidden up the top inside & outside (behind water screen fluid bottle and inside wheel arch near windscreen.
open door and unbolt the 2 bolts that are only accesible when door is open then check for other bolts.
