Removing Wiring Loom
  clio 172
Ive disconnected the majority of it, ECU has been removed and fuse box removed.
The wiring loom seems togo behind the exhaust manifold but i can see behind and i cant get the 2nd bolt of the manifold flange meets the cat pipe
can the manilfold be pulled up through the engine bay once i have removed the engine and gearbox ?
  clio 172
Ive taken all the manifold nuts off and disconnected at the cat flange under neath the car but the manifold doesnt want to come off freely so was going to wait until i have a engine lift to support it and move it forward to ge the manifold off then try getting to the plug and nuts to disconnct the loom.
  182, SQ7, Trafic
You also have a plug going to your cat for the lambda sensor/s, but you should need manifold off for others.
