Could I get it to work with the omex? It has a output on the new loom for the tacho but is the signal through CanBus? I.e would it need coding to run the sagem tacho?
What do you mean by Coding? The Omex has no CANBus so if it requires a CAN input to the dash cluster this isn't going to happen, ever. You need to bear in mind that you need the Renault CAN protocol as well for the dash to understand whats coming into it.
What you may be able to do is pull a dash cluster apart and drive the tach directly from the Omex. There is a rev counter A/M/Offset in there so you should be able to get it reading about right.
