Quote: Originally posted by MattT on 30 March 2004
Cheers guys.
BlackClio16v - Its one of them Belkin things that you stick into the stereo jack of an mp3 player/cd player etc and it transmits whatevers playing to an fm frequency you can tune your radio into.
Tom - Do you know what connecter an aux-in adapter would use on the back of a HU? I think the standard Reno HU supports a CD changer, so if it does will an aux-in adapter work the same as a cd-changer? Assuming they use the same connector on the HU.
the modulator theyre talking about actually allows a direct connection to the ariel connection, to provide a better signal.
an aux-in connection should be two RCA sockets, afaik very few oe headunits have a socket on the back to connect an adapter to, and even at that, the connecter is usually just for pre-outs, not inputs.
Personally id just forget about trying to get an aux-in adapter for it - if its availible then u can get one from renault, if not then just forget about it, not worth the hassle, and to be honest i dont think itll be possible (not without a bit of work anyway - the amount of work that makes it not worthwhile with the standard headunit)
