replacing comps
  Corsa C 1.2
hi guys right my mate has a clio but has no common sense so im having to do this for him. he's just bought a 2000 clio grande and im selling him my old focal comps for the doors, now how do i get them off it seems a lot more complicated than it is with my corsa.
Any help you can give me would be greatly appreciated
cheers, steven
  Ph1 172 + Combo van
the covers just pull off from the bottom. or just get a flat head under them at the bottom.
then just unscrew and run your new wires into the car through the rubber grommit and up to the dash. tweeters will need some modification if they are too large for the hole. both crossovers can go under the dash too.
  ValverInBits
if you want to run thicker wire, it can be a bit of a ballache. On my MK1 I had to use a drill to make get a little more space in the connecting block to push the wire through.
As said, tweeter positions may need modification.
