Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
I'm going to drain my gfs coolant and replace, i'm looking for some guidance.
What hose do u disconnect to drain the fluids?
What type of collant to you repace it with Blue/Red etc?
there should be a "tap" on one of the bottom corners of the radiator just turn that and it will drain the coolant and replace it with new coolant which you could get from a renault garage. not sure how much coolant it will take to fill the system but if u get the coolant from a garage you could always ask. hope this helps
Remove the bottom radiator hose to drain. There wont be a tap on the mk2's.
Then refill with coolant and water and bleed the system via the valve cap thats on the thermostat housing. Road test, make sure hot air out of vents and re check level.
