Road Angel 2
Car  liquidized RacingBlue 182
so anyone use them? how do they find them? saved some asses? i just bought one so curious to see how they are!
You wont get coverage through your windscreen as its Uv protected. Need and external ariel that can be put inside near the back window or under the plastic cover under windscreen.
I don't need the antenna for my 182 Cup (I did have the antenna but sold it on here).
It has saved my arse loads of times but is useless at picking up handheld cameras. Ideal if you commute lots and use roads which you don't normally go on but if I drive around local I never use it.
