Okay so last week I bought myself a nice second hand exhaust system for £90, was quite happy with it and after some troubles getting it on I finally managed it! Upon the first couple of runs I was relatively happy, and after a longer 70mile run I was even happier as it pops when letting off the gas when hot! But then concerns have set in as the system has a decat.. Then I have come to realise it might not have been worth the hassle,
After doing various searches I have read the following..
Roadside checks
Your vehicle can also be tested during a roadside check.
If it fails the check, you’ll be given a prohibition notice. You’ll have 10 days to fix the problem. If you don’t fix it within this period you may be prosecuted.
If your vehicle is seriously in breach of the legal emission limits, or if it has other defects which make it dangerous, the notice will come into effect immediately. You won’t be able to use the vehicle. You may also be prosecuted.
Now really though, what are the chances of this roadside check happening? I've never been pulled before and had exhausts louder than this but never the decat. And what do they define as Serious breach?
Roadside checks
