Rocker Cover Gaskets
  172 cup,s2 rs turbo
try putting a very thin smear of sealer on the gasket before you fit it.also put threadlock on the bolts to stop them from working loose.
did that Jay funnily enough. the seals round the plugs (little orange ones) 2 of those have gone too, so that obviously isnt doing me any favours either
  172 cup,s2 rs turbo
the little orange plugs are just dirt seals etc.they serve no purpose where the oil is concerned.geniune gaskets are suppossed to contain a substance that causes the gasket to stick to the metal.try fitting one without any sealer but put threadlock on the bolts so they dont work loose.
yeah, i can see about the sticky substance as the previous one was well stuck on and i had to give it a good clean to get all the residue etc off before i fitted the new one.
  Mr2 Roadster
Quote: Originally posted by stan* on 16 February 2004
r u torquing the bolts down correctly??
Thats as tight as you can do them with one hand, a can of stella in the other and a joint on the go isnt it?
