RS Tuner Advice / Help
  wanting a 225or197
Just got my RS tuner through the post :D
I assume you have to load a .rst file and a .cal file?
So i have loaded:
.rst: 6400_2A07 (base group N setting)
and
.cal: 6400_2A07 RON98 aug 2008
From the files on fastchips website what is the best combination of these files?? as there are more .cal files to chose from.
can you load more that one .cal file?
ecu is CB1N
cheers for any help!
Nop just one .cal file. Pick the one which matches the .rst file.
So the two you have there look correct (assuming they are correct for a CB1N engine)
  wanting a 225or197
ok chers for the reply.
do you know what the differences in the other cal and rst files are?
