RS TUNER PA
Car  Clio182 Astra2 GTE16v
Just ran a PA on 182, running viper and scorpion cat back, original file 8100 7803 upgraded to 8200 7804 rst and cal, managed 99KW on third gear run, surely not right. Input 1220 kg car, fuel and me. The NM was about 161. Standard I believe is 200 and 131KW, whats wrong. Fuel 99 super unleaded. :dapprove:
Will run another run tomorrow.
It is a bit low but remember that RSTuner gives you the power and torque figure at the wheels whereas manufactures state the figure at the flywheel. The reason behind this is the flywheel figure is always bigger as its taken before drivetrain losses etc and customers like bigger figures (apart from price)!!
To get the results more accurate you need to do the run on a flat road with no wind and get the weight as accurate as possible. Best to do a few runs as well.
I beieve the ecu goes through some sort of learning curve on initial set up, came back this evening and its certainly quicker and now redlining at 7800, sorted.
If it wasn't redlining at 7800rpm before then the engine wasn't warmed up correctly which would explain the lack of power.
Cutout at 6800 so your right, just to eager to try in out, well boot it to be honest. Really pleased with the result, but I want more, group buy on decat I'm in.
I'm running 100 kg pay load in the drivers seat ! so 1090 clio kerb weight 1/2 tank fuel equates to 1220kg me thinks, on a diet now !
