RS Tuner
Do you mean from someone who has bought 1 already? as they get locked to the ecu mate, you will need to pay to unlock it from the 1st persons ecu then when you have remapped yours you'll need pay to get it unlocked again to go back on there ecu - big ball ache - prob better buying one. If you mean with an RS tuner you have bought then im sure someone will help you
GazM, whats the data logger and performance monitor etc like.
just a quick question a little off topic but has anyone got their 02 sensor voltages from the live feed. my rear sensor stays on around 340ish but changes every now and then but my front sensor ranges from 70's up to 700's within seconds. Anyone found theirs does this?
That is normal. The rear O2 changes slowly. The front O2 alternates fast between a low and high level voltage during closed loop.
ok thanks fastchip, also is the knock sensor suppose to be around 30? mine changes to about 50 when i drive but around 30 when idle
I have only used it once so im sure someone else would be better to inform you but from my limited use im impressed. I only used the PA before the remap - need to do another after to compare
