rsi side skirts how to get off
  Twingo 133
There are 5 rivets along the bottom rail which you need to get off. i found these pretty tricky to get off.
there is one bolt at the end of the skirt which you need to undo.
there are 3 bolts at the front i think which you need to undo.
and then open the door and there is 3/4 bolts which you need to undo and then the skirt should just pull off.
