RSTuner Software Versions
fil_b
  172 FF and Fabia VRS
Hi
I just backing up my ecu atm
it is version 7300
i have the 7300.cal file to go with my ecu, but the groupnfile is 6400.rst
can i still use this???
clio 172
CB1N is my vin
please help
thanks
phil
  RB 182 & Lotus Evora
I believe you MUST stay on the same software version. Ie rst.
So any rst starting 7xxx, you can not downgrade to 6xxxx as far as im aware.
fil_b
i just pm'd u back lol
ok i need to have a word with henk on what to do then
fil_b
can any 1 help or know of the group n file??
not heard off henk in a few days
have sent a few mails
group N was only done for the 6xxxx software, the 7xxxx only supports the calibration series. So your only choice is 7300_5E10 RON98 may 2008 .cal
fil_b
ok i upload that tomorrow
then see how that settles in
still not news of henk yet
fil_b
will do
will be tomorrow when i try it as i left my laptop at work
ignore my email henk
just seen you updated all the files on the site
will there be a group n map for the 7300 software??
short answer : no I think he said there wont be
Henk: can you let us know what the revisements were in the latest .cals files? Any improvements?
fil_b
1st impressions of the .cal file
no idea what the old one was like i have just used the new one
Uploaded it and the SERV and TC light stopped on.
But the car so much smoother, and pulls loads better now
need to gave it another few more runs may improve more??
but defo impressed with the way things are currently
Let henk know. This is obviously as minor glitch and a new update will need to be made.
fil_b
its ok now
was just the 1st time i started the car
going good atm and improves every time i drive it
takes 10 cycles to settle down. Im on may .cal file so might update tonight if there is improvement to be had :)
fil_b
I had my engine management light come on this evening using this updated 7300map.
Done about 70miles on it currently
has anyone else had any issues with the up dated 7300 map??
send henk an email this evening - will let you know what i find.
feebs
fil_b
when i hooked it up
i got
THe only that was showing was the limiter error.
Then after a few seconds the other one appeared
"initialisation backup memory" - whats that about???
i tried to clear them but they still there but the Management light has gone off currently.
