Rubbing noise, Bit of help please.
Hi,
Had a rubbing sound when turning right only and its starting to concern me, Its not very loud, Just sounds like a wobble rubbing against something. No tyres are rubbing against anything as far as i can tell.
Ive checked all the nuts, There fine. Thought it was the rear left wheel at first, But now im thinking its the front left. Checked all shocks, Cant see any leekage. Cheecked the CV joint (not sure if that could be a problem if it was leaking, But thats ok on both fronts too).
Both front tyres (left and right) have a mm or two of movent left to right, I dont know much about mechanics, Is this normal?
Had a front left ball joint replaced for MOT last may, Can it be gone again?
Also front strut mounts, Think there called that.. Have a 2 mm gap between the rubber and the part it sits on.. Is that normal?
Sorry for all the text, Cheers if you can help.
