Hi People
This is my sceond Cup now, just need a bit of advice from you lot. I part exchanged the old Cup because of an accident i had when it was snowing a While ago. i damaged the suspension, sub frame, steering rack, it never felt the same again.
My first cup, i ran it in nicely under 3k for the first 700miles, but the new Cup i have done nearly 550miles and have taken it up to 5k quite abit. Is that bad for the engine. I Just thought of running it in on higher revs. Apparently the car gets used to you ragging it a bit so it responds better, is this true or is this aload of b****cks.
Even with 550miles on the clock its performance is brilliant. It picks up straight away when flooring it to about 5000rpm maximum, i have not taken it any higher.
Will this cause any damage.
Please advise
Cheers.
