scrubbing!!
  Lunar Mk1 & Flamer
got 16" wheels on the valver and its lowered 40mm.
wheels scrub like a itch on full lock.
how can i avoid this?
  Mégane RS
have the arches rolled or take the arch liners out
A good angle grinder should do the trick ;)
  Mégane RS
surely the wrong offset then mate, check your alloys, usually on the back lip of the rim
  Renault Clio Mk1 1.4 RT
Cant understand how it rubs!!
Are you running a high profile tyre??
My 17's don't really rub - only a little and thats when i brake and turn into a corner other than that they dont!!! My car is lowered 35mm on front and about 40 on the back - only arch mods were a mallet to the inside of the arch with the wheel off!!
Won't spacers push it further into the arch??
Cheers,
Dumpy
  Punto/Clio GTT
will push it further outwards towards the kerb, but i think his is rubbing on the inside by chassis leg? so needs spacers not higher et or archwork
