Seat position sensor df065 fault code
Car  Clio 172 Merc ML55
Hello, I've been chasing airbag faults over the last couple of days and I'm down to last fault code of df065 which is showing for drivers seat position sensor, I've tried the resistor trick but with no luck, with either ignition only or with engine running I have between 3.4 and 3.7 volts on the pinky coloured wire but as soon as I plug resistor in to the grey multiplug I lose voltage? I'm thinking possibly wiring loom damaged?
By the way standard seats have been removed and buckets are going in
I'm kinda at a loss as to where to go next, been searching through the forum but not found anything specific with a fix, hopefully somebody has sorted this before
