i have a fake electric dremmel and have a compressor just need the tools which are cheap enough
what did you port them too???? the gasket size?
Notice difference?
I'll buy another standard one to port then![]()
I used a carbide burr in a electric drill, then polished up with 60 grit paper in a flap wheel.
Yeah I just ported the lower inlet out to the gasket size top and bottom, then made sure the top half matched the lower part of the manifold.
if you went out to the gasket on the head end of the inlet, you went too far
anyone can port a head.
but whether they can do it properly and an even job across all ports is another story. If it was easy to then tuners wouldnt spend thousands on cnc machines and flow benches.. even then there is still a good few hours work involved.
IMO clear any casting imperfections and leave the port work alone.
And also note if your going to do the full port , the finished texture also plays a part in how it will run/ perform.
