service and airbag light??
  172 Credit crunch edition
my service light and airbag light came on the other morning. Both together at once?? any ideas chaps?
Da
  Less
waggle the connector under your passenger/drivers seats mate. They sometimes come loose illuminating your dash lights.
KDF
  Audi TT Stronic
^^ yep.. 99% of the time its that cable.. the renault fix is to cut the cables from the connector and solder them together.. good ol renault !!
Seat belt warning light
The SERV and AIRBAG lights come on its a common problem (almost every has it) its due to the wiring of the pretensioners going to an open circuit. Fiddle with the wires under the seat an the problem will go away.
On the early cars the solution is to look under each of the seats. You will see a grey connector.
On the passenger side disconnect it and cut the Blue and Brown wires off both sides. Then solder the Blue wire to blue, and the Brown to the other brown. Make sure you use insulating sleeves over the soldered connections..
Under the driver seat there are two pairs of wires in the grey connector.. Only cut the Blue and Brown wires and solder them together as above.. Reconnect the connector..
On the facelift cars it is ONLY the passenger side connector that is affected.. So again cut and solder the Blue and brown wires.
