Mk1 Maxim Sport
Hi all,
Hoping someone can help as I'm having no luck. The last post I made on this forum was back in 2008!!! somehow I'm back to owning a Clio and somehow I managed to clip a low brick wall with the other day! Bloody nightmare.
Anyway, its put a dent in the nearside sill which i've had a bodyshop look at and quote for which is fine. The issues im having is with the decals and chrome side trims.
I cant seem to find either of them online or the correct part numbers. Its a 21 plate Clio Launch Edition Hybrid, but for some reason it seems to have a different side trim than all the other 21 plate Clio's im coming across. The chrome trim runs across both front and rear doors, is straight to the end and has CLIO printed into it on the rear door. (See pictures). somehow I made a mess of both the front door and rear door trim so thought it would be easier to just replace both, if i can source it!
Next moving onto the decal, the bodyshop stated it would cost over £200 just to replace the decal because apparently they're hard to find. If this is the case, ill just have them remove the decal from both sides and not replace it. Not paying £200 for a sticker. Does anyone know of anywhere I may be able to source it for a reasonable price? Again see pictures.
Hope someone can help, I remember back in the day, I used to be able to pull my mk1 apart and put everything back together again with the help of this forum.
Cheers in advance!!
Cheers in advance!!
