Side repeaters
also has anyone bought the side repeaters from demon tweeks. gonna get the smoked ones. they fit easily enough? is it just a case of chaning the bulb and popping in the new repeater?
Hi, got mine for my 172 from DT - mention ClioSport and you might wangle a discount. They do fit the MK2 with a bit of adjustment. Your old ones will pop out, place small screwdriver under one side of repeaters and one side will pop out - then with a strong pull the repeater will come out - mind paintwork though.
The new ones need a bit of tweaking, you will see four plastic bits on inside of repeater - you need to lose these. Best way is with a dremmel, i did mine with plies, wasnt a pretty sight but when they are on no one can tell. Well worth doing though and best mod for the dosh.
GR7
  Shiny red R32
ClioJohn, phone John Harris@DT direct on 01978 663 057 and he will sort out your side repeaters for you, mention Cliosport and he will give you a discount.
  Renault Laguna Coupe
If you dont fancy using a screwdriver the corner of a credit card will pop the repeaters out with less risk of scratching your paintwork.
  Ford Fiesta
just use a towel and it protects paint. I used an ordinary eating knife to chop corners off new smoked ones. fitted perfect
