silvervision
Car  Clio 172 Cup
right guys i need some advice - i want some silvervision front and rear indicator bulbs, and there is something about a free pair of sidelight bulbs. So if i get 2 pairs of silvervision bulbs, then i get the sidelights free? Is it worth losing your hand fitting these bulbs?
so wat are the silverfusion ones? Just the same? Different name? Do tyhe silverfusion ones light up amber when u have ur indicator on?
hold on!!!! How do they know if the fitting is right? There are opposite and offset? And on the powerbulbs website i didnt have to specify that? Which ones does the cup have?
Just done all of mine this morning in about twenty minutes.
the drivers side was the hardest because of th A/C pipes but they should be quite easy on a cup unless youve got sausage fingers.
The SilverFusion ones are similar, but different and area actually fully silver to look at, wheras the SilverVision ones still have a slight orange cast, like you can just see in jon_rs pic above...
Got some of the SilverFusion ones in mine from http://www.silverfusion.co.ukwww.silverfusion.co.uk and they really look good.
Look >>>
Just like a shiny chrome ball now, with not a hint of orange, but when they flash its still a proper bright orange, so theyre good.
I couldnt be arsed with paying £15 for a pair of sidelight bulbs as im a tightwad, so i sprayed some orange indicator bulbs with a thin coat of silver plastikote.
Youd be amazed how effective it is. Although i reckon with sidelights the heat would make the paint come off, but fine with indicators and there is NO difference in clarity.
