Simple Batch file which I cant do! Copy/ Move
  E39 530i
Need a batch file which does the following. Copies all files from c:\folder1 to c:\folder2, then moves all the files from c:\folder1 to c:\folder1\archive.
I can do the copying process but not the moving part any ideas?:mad:
cheers
  Trophy #267
not sure move does folders, only files. it may work if you have no subfolders.
Alternatively rar them via cmd line to the archive & then delete
c:\rar.exe a -pPASSWORD -dh c:\destination.rar c:\folder1\*.* is what we use
  E39 530i
xcopy "\\server3\calls\company\xyz.WAV" c:\test\local /S /Y
move "\\server3\calls\company\xyz.WAV" \\server\Calls\company\Archive calls
Ideally I want to copy all the wav files within the company folder, and move to the archive folder, but im just trying it with one file first.
  Cupra
You need the inverted comas around the last section due to the space in the name:
move "\\server3\calls\company\xyz.WAV" "\\server\Calls\company\Archive calls"
