Re: sky is s**t
Bash,
Apologies for not answering before.
I'm not at home so can't check this now.
Basically, channels like E4 and greater, including music channels and so on are having the issues. however 501 is fine.
The engineer said the signal was very weak and we resent the LNB's, we still had the same issue, he said he would try and boost the signal, which could take 30 mins to an hour.
I can check this channels when I am at home.
Thank you very much
Its my fault, I have been spending too much time on here saying sorry rather then working today. Rain will effect ur service as radiation cannot pass through water, as for wind gusts can cuse the dish to flex and lose its line of site to the satellite. Thats the problem with sky tbh. You will lose certian channels before other ones due to transponder beams. However here is a way to check ur LNBS.
Answer yes or no to these questions:
1) Can you see Channel Wonderful?
2) Can you see the Audi Channel?
3) Can you see Ben TV?
4) Can you see JML Choice?
This will check all 4 LNBS.
Let me know your answers.
Bash.
P.s I can confirm everything is ok.
