smoothing info
  Bmw M4 & Clio 16v
I need to get some info on how you would go about de handling and smoothing a clio door? think you need to weld in a panel and then fill?
where can i find out the correct info?
Your car will not pass the MOT without door handles matey! Its a safety issue as if ya roll it and your are un-concious Mr Fire man cant get you out! I have heard of people having a switch or lever fitted under there mirrors but im not sure on this either as the fore mentioned Mr Fire man wont know where it is!!
Dont take this as gospel it is just what i have managed to work out reading other peoples posts!
Im sure someone on here will be able to put you right if i am wrong!
smokey
You only need one exterior lock on your car to NOt fail your MOT so i have been told so as long as you keep the boot lock MR FIREMAN will have to go in that way to pull you out!
  Bmw M4 & Clio 16v
no door handles no door locks no boot handle or lock either. just two buttons under wing mirrors like the TVR
