Spacer problem !
Just recently bought a set of 4 25mm hub centric spacers, I have the kind that the spacer bolts to the hub then the wheel bolts to the spacer.
Now the rears are totally fine and so is one of the fronts.
but one of the fronts keeps coming loose even though i have tightened them up, I have even tried taking them off and re fitting them again. but its always the same one. even after trying it on different hub.
I was wondering if its a problem with the bolts i have? or could it be something to do with the surface its on or that. i have heard of problems to do with them on a non sanded surface. once tightened it seems fine but the more i drive a slight knocking noise appears and then drive more and then get home and the spacer has loosened its self a bit
But if anyone has any ideas it would be a big help.
Cheers.
  Polo BlueGT
What kind are they? Delta mics? I have some bolts for them if you need... I also have the 25 mm spacers to go with them ;)
