Spax RSX 'Trackday' damping settings
Greeny.
Car  440i + 182
Just wondered what you guys are running on your kits front and rear for road and/or track use?
Dan
I came across a thread a bit ago with a few pages in, all off people stating what settings they were using on the rsx :) Not sure where it is now mind..
Didn't even realise you could adjust the front dampers. Got the rear ones set halfway so I assume the fronts are the same.
Tbh I couldn't tell much difference when I turned the little switch all the way to the left or right after taking it on a little drive.
I only drive mine on the road though. You'd probably be able to tell when racing round a track.
Mine are 14 clicks from soft on the front and 16 clicks from soft at the back. Possibly a little too hard at the back with the rear stripped out but not really had a play with them.
The rears make load of difference to me, I changed mine down 6 clicks softer and road driving was alot more bearable.
My fronts were set to nearly fully soft... im a r****d basicly. Now changed to 16 clicks from soft and ALOT better to drive with, also put my tyre pressures to Renault spec which might have helped, however they are now harder!
