Hello...
How old is the car..?
What you mean by the radio..? is it in FM..MW LW..?
You will find that FM works different, as FM sends 3 radio signals into the radio, so therefore you get the better sound quality than the MW LW (aka AM). The higher the frequency, the shorter the aerial..so hence the tiny mobile phones...<--get it..
Now..MW + LW... These use really really low frequencys so therefore need a longer aerial, and the signal is only 1 signal, so therefore i can be affected. Thats why you lose the signal when you go under a bridge in AM...
So what causes this..? If you are using LW or MW...aka Virgin 1152 or Atlantic 252....Radio 5 live...909.....
The alternator is a generator, inside this, there is a motor which is made up of a iron core with copper windings wrapped around this, this creates eddy currents, which are put up the care wire, chassis etc..So im MW + LW (aka AM) you find that if you put the radio on, and engine, and rev the engine you hear a high pitch squeal, and tone change..
How can i fix this..! Go to halfords as ask for suppressor..aka suppression unit, which should filter the interferance out..
What id do..!
1. Suppression Unit.. (goes inline of alternator...)
2. Aerial... doh...(monkey see monkey do)
3. Radio...
Alias....
aka Aircraft Radar, Comms, Navigation, Weapon Aiming -- Expert..
