Only had the Cup two days but today the speedo needle dropped to zero & the engine note changed, the computer stopped counting mileage too. Started working again after couple of minutes with same change in engine note. Did it twice more on way home. Any ideas? :S
Help a damsel in distress please?
Jaine
Can be signs of a the battery on its way out, sometimes the trip computer and mpg etc will stop recording when the battery voltage isn't as high as it should be, might be worth getting it checked at your local garage, should be free of charge. Also every time you stop then restart the car, all of the trip computer settings will be reset.
As to the engine note though, I’m not 100% sure, but on the phase 1 non sport Clio’s, the sensor in the gearbox which controlled the speedo would sometimes go crazy for a couple of minutes, then start working again. Renault used to sell the sensor and a new plug to attach to the loom to solve it. Unfortunately I’m unsure if it's a similar set up on a 172, hopefully someone can help you out on that one.
