has anyone start off with just springs then got a damper set after, as i want to know will the ride comfort be better if i got myself some koni dampers on the softest setting.
th ride is firm and u just have to swerve for the potholes, also speed bumps are a pain the arse. but the benefits are less dive when braking (which is good as if i braked hard in the wet it is very easy to lock up, now its more stable), less roll round corners and more stable at speed. oh yeah it look the b****cks slammed to the ground!!
Errr, youll probably get the opposite of what you want? I started with the torsion bar adjusted and lowered springs on the front and it handled lovely, then went for the Koni shocks later - gave a harsher ride. But much better handling though.
If you want an armchair ride then keep your original shocks and keep replacing them every 6 months when they knacker. Or go for a harder ride with better handling and get a proper damper set for lowered springs.
