splitfire plugs in a 172
anyone fitted these at all - if so any good or bad points about them - seem quite cheap compared to denso etc - any recommendations - cars done 26000 miles now so about time to change them i think
Ali
  V6, Trackhawk, GTS
^ i've got the bosch one's. Cheap as chips and do the job, no performance advantage although the car does seem to start better....
thats cool then - I just checked my ebay account and saw that I have actually bought the bosch ones not splitfires so all is cool. Are they easy to fit - I know they are easy on a normal engine but you cant even see them on a 172 - I presume they are on the plenham under the engine cover??
Ali
  V6, Trackhawk, GTS
You have to remove the plenium. 4 bolts i think. Then it's a deep socket 16mm iirc. Piece of cake. The hardest part is getting the plug out lol...If you don't have one of rubber bits inside the deep socket.
think i have got 2 spark plug removers - bound to both be the wrong size but sounds easy enough. Thanks Ali.
Hope they have come in the post today now
MRBILLYUK
  FF Jeden Osiem Dwa
Take care not to cross thread when your puttin' the new plugs back in .
A good tip is to get some 10mm flexible plastic tubing , put that on the end of the spark plug to start it off , if its not on the thread properly it will spin so you know its gonna cross thread , then once you've started it off use the plug socket .
Plus i always put a tiny bit of copper grease on the thread , makes it easier to get em out next time .
lol thats confused the fook out of me! whats the plastic tubing for??
Ali
  V6, Trackhawk, GTS
timsclio172 said:
lol thats confused the look out of me! whats the plastic tubing for??
LOL...Me too! :(
Plugs only need a very low torque setting. And cylinder heads are all very weak. So be gentle. When it feels vaguely tight...Stop!
MRBILLYUK
  FF Jeden Osiem Dwa
If you put the end of the spark plug in the plastic tubing , then start to tighten it up that way , IF YOU DON'T get it on the thread and its gonna cross thread the tubing just spins round .
Once you've got it started with the tubing , then use the plug socket to tighten it up .
Do you understand what i mean now ?
  Black 172 MK2
basicly if it doesnt move your in the hole and keep going, if the tube spins on the plug then your not in the hole so start again
MRBILLYUK
  FF Jeden Osiem Dwa
If the tube spins , then your not on the thread properly, because the tube is only tight enough to hold the plug just enough to get it started .
If you think that your on the thread and you use a plug socket straight away , it only takes a couple of turns then your threads fcuked up :(
  TDI tyre shreader
Sliptfire spark plugs?? Do they still make those joker 15bhp gain plugs? Stick with your platinum plugs they will be much better
  Skoda Fabia vRS
Splitfire plugs are supposed to be some cheap american brand plug called Autolite with platinum bits stuck on
actually not that good from what ive heard
