Splitter help!
  Glacier White 197 Cup
Hi. bought a 172 splitter and wondering what the proper way of fixing it on my ff172 is. I have 7 screws that came with it. pics would be good cheers!
Herdie
M
mij29
Think if you feel under the front bumper you can feel where they go.
I'd start fro the middle and work my way out.
Steve
  ST3 8.5
There ain't no place to fit it too if you understand.
I put mine new on yesterday, trying to line up old holes was a waste of time.
I started fixing each end, then the middle & work your round.
I needed more then the screws supplied, i think some bumpers are more level than others.
It's a bit hit & miss but you will get there in the end.
My old one is in 2 bits, anyone want it FOC before i stick in the bin.
Christopher
  Z4M
mark the middle on both your bumper and you new splitter
(if you are replacing a broken splitter DO NOT use the same fixing points, sand down the burrs and mount at different place) it'll just pull out otherwise, i know. lol
work from the middle of the bumper to each side seperately, being careful not to over-tighten the self tappers and making sure the splitter butts up to the bumper correctly.
repeat for the other side.
if you're fitting to a non ph2 rs (like my 172 ph1) you will need to bend it a bit to shape and trim the excess of each end and sand down the cutting burrs.
dead easy to do on your own if you do it that way, about 30 mins work.
  www.renparts.co.uk
Ill paypal you 10 quid if you post it, clean break?
Steve
  ST3 8.5
Photos of splitter, it looks like it was broke partly from new due to being split by screw.
  • for sale 001.JPE
    for sale 001.JPE
  • for sale 002.JPE
    for sale 002.JPE
  • for sale 003.JPE
    for sale 003.JPE
  Clio 172 mk2
Herdie
If you want to do a proper job remove the bumper tape the splitter in postion, drill the holes and secure using small, 4mm allen head bolts with washers on both ends.
Rock solid fitment and guaranteed not to come off/get pinched.
