Spotlights not working
  1.2 16V Clio (Blue)
Might just be a fuse or the wire but is this common on a Dynamique they ain't worked since I got it and if it's common what's normally the cause of it?
  Clio 182 arctic
over use
1st try the fuse then if it aint that make sure all the plugs/connectors are in properly behind the spots. then try a new bulb.
  clio 182 full fat
Thanks buddy will have a read now, going to check the bulbs tomorrow my thoughts are if this was the problem only one will have gone down not both. so must be something else
Check the wiring loom under the bumper by the passenger side fog light. Get a multimeter on the connector and see what you get :rasp:
I had the same problem - cleaned up the contacts and they work fine.
