Oval plate
The oval plate on the Mk2 Clios is found on the bottom the the drivers side pillar down by the sills. It tells you a lot about the car the example below is a 1.4 16V (see the list above for a conversion) the details for cars will be different but you get the idea I hope.
CB0P-is the vehicle type
F003655-is the vehicle fabrication number (manufacture date)
E2-is the equipment level
SAN913-additional limited addition spec
SAN513-additional special edition spec
0V727-paint grade and paint colour
DRAP03-seat upholstery/coverings
HARM01-interior trim colour etc
5-technical specification in relation to coutry. sometimes referred to as
the special features code
ACGK-main options,these are:- A=normal suspension,C=temparate climate,G=non regulated aircon/heating,K=without pollen filter
NRTV-main options,these are:-N=pas,R=without variable shockers,T=without
self level suspension,V=with abs
Other variations of main options are:-M=manual steering,P=variable
pas,D=extremly cold climate,F=normal heating,H=regulated aircon,J=regulated
heating but no aircon,L=with pollen filter,W=without abs,U=with self level
suspension,T=variable shockers.
