Spraying door handles?
  Clio 1.4 16v Dymanique
I HAVE FOUND THE ANSWER TO THE ORIGINAL REASON FOR THIS THREAD... SORRY
HOWEVER IF ANYONE COULD ANSWER THE FOLLOWING:
On removing the side bumper stripes because I'm getting them sprayed too, i know you open the door and push towards the rear, I'm assuming this takes some force?
But how do you remove the door bumper stripe on the back half of the car, open door and then just push towards the front of the car?
Cheers Guys
  3 Series touring
did this in the week, its simple if you know how.
FRONT:
under the bottom side of the bump strip on the end closest to the door opening is a small peice of plastic that holds the strip in place, simply mask up a screwdriver and use it to hold the bottom of the strip away from the door...now push the strip towards the door opening (with the door open) or get someone else to do it.
REAR:
same as the front, there is a small plastic peice towards the door opening, use the masked up screwdriver to hold the bottom of the strip away and push toward the door opening.
just bear in mind if its not working that there is a loas of s**t and dirt stuck down the back of the strips (im my case 7 years worth) so it might be hard to do...just keep going!
