When you say your clutch squeaks, do you mean the clutch ped is making a noise or is the sound coming from the engine compartment? i think youd know if your clutch was on its way out to be truthful.
Sounds like you could do with some WD40 behind that pedal. careful tho, could be alittle dangerous if you got some on the rubber grip pad.
