squeekin like f**k
passenger side top mount is squeeking like fuk wen turning wheel after the lowered suspension drop...60mm ktec racing lowering springs....car sits just how i want it...just started gettin worse and worse squeeking..its deffo the rubber top mounts makin the noise...n its bloody loud!...tried givin em a load of wd40...is it poss i hav tightened them too much...dus any1 hav a pic of how much ther top mounts are tightened????...strugglin 2 solve dis one guys so any help?....cheers.jak
Nah i don`t think you can tighten them too much. Its probably just the extra pressure from the shorter harder spring. When i dropped mine 40mm on progressives my suspension noise got more prominent.
Samuel
can any1 help :( ??? wot 2 du to stop squeeking...its really loud...inside and out...grease? loosen up a lil ????any advice
Try you front outer anti roll bar bushes mate take em out and grease em or swop em only cheap from ren £12 pair ithink thats what mine was :)
