ss brake lines
  KTM 990 SD / S60 D5
just purchased some ss brake lines for my 182,how many lines should there be,there were 4 in the pack but looking at the car it seems I may need 6,any help would be great thanks.
  Seat Ibiza
There should be 4, the longer ones for each of the fronts, and the two short ones fit on the NSR just in front of the beam. The for the rear calipers don't exist, people say they're not needed.
maynard
  ph2 172 track car
Yep just 4 you need.
Good luck in getting the short rear ones off though - mine were seized solid!
  Seat Ibiza
Mine were alright, but I sprayed with WD40 a day before. If you can get hold of a brake pipe spanner too, makes life easier. I think its 11mm and 14mm you need and a pair of pliers to pull the old ones out of the holders.
  RS 182 CUP
special brake spanners are needed, so easy if you got them! if your in mids i can help out
