Stalling with the clutch in
Hey guys
Just recently when driving my car from cold ish, I let it warm up till the fast idle stops first.
I drive round the block, and when I dip the clutch she stalls, no juddering or anything, almost as if the in gear clutch down map (if there is such a thing) is playing up.
She doesn't do it when the engine is up to temperature.
I dont have any clutch slip while driving either.
Any ideas on what this could be?
try removing and cleaning the throttle body also have the battery disconnected whilst you do this and leave it 10 mins or so that way the ecu parameters will reset
Cheers guys,
Is it difficult to remove the TB, I had the airbox off at the weekend (after these problems started), so I know I can get to one side easily enough.
I have some old carb cleaner, could I use that and a microfibre to clean it?
No I havn't steam cleaned my engine...?
